SU IC boost tubes
Bonafide_Spd3
2007 Mazdaspeed3 GT Cosmic Blue
Has anyone purchased this upgrade? I probably won't buy an IC upgrade for probably another 3 years and was wondering if there would be any benefit from this mod. Any suggestions on this topic would be appreciated
I just installed the SU boost tubes three days ago. I only did this because I stripped one of my clamps trying to tighten it down, and figured I'd go ahead and do the boost tubes for the heck of it. I think there isn't much noticable gain at all from the tubes themselves. Unless you've replaced your turbo or something, the stock tubes will be just as effective. What you should definitely do though, is make sure all four of your boost tube clamps are tight. They come pretty loose from the factory and tend to loosen up as time goes on. Just make sure you don't strip one of them like I did!
I would recommend using t-bolt clamps. When you tighten them they stay tight. They don't strip out like worm clamps also.
Alright, appreciate the reply. I wasn't sure if it was worth the buy or not. I'll check out my tubes tomorrow
