- 02' Protege ES (Gone)
16' Mazda 6 sport manual
So schweet, I demand sound clips ASAP
Ok so your mods are.... very quick skim through of thread
Twigs
MT EMS
Adjustable cam gears
PnP head
Coated 10:1 pistons
Over sized valves
626 manifold
header?
test pipe
?inch exhaust
wow man congrats. can not wait to see pics or vids.
I'm having trouble getting idle to settle down. I loosened the screw in the TB quite a bit and the car still wants to idle around 800 rpm (which is what i would like) but when the car gets hot (~92C water temp) it starts ocsillating and dies. If i hold the gas pedal down 2-3% it will idle just fine by itself just below 1000rpm, MY afrs are reading around 12 at idle once the car is warm. Is there too much fuel? do i need to add a bit more? the car used to idle 600-700 with the stock ecu and afrs 14-15. IAC is still under stock ecu control.
