READ THIS IF YOU WANT TO CERAMIC COAT YOUR MANI. I'M SERIOUS. If you coat the mani right from the manufacturer, the coating WILL flake at the welds. There is oil in the welds from the welding process. Install it and drive it for a few days first before you have it coated. I guess you could also heat it up real good (Evenly) with a torch a few times. Get it real hot, but very evenly.
Mine flaked at the welds because of the welding lubricant used in the manufacturing process. Performance Coatings is going to re-do the coating free of charge, even though it's not their fault. Great company!!!!
By the way, mine is ceramic coated and i can touch it about 5 min after I turn off the car. The hottest I have measured it so far is 720 degrees at the turbo flange and 620 degrees on the tops of the runners. No glow-in-the-dark on my mani!
GET IT COATED!! It makes a world of difference!
