TBK Performance New Monster !!!
Status
Not open for further replies.
Man i still think id upgrade to a PWR radiator, AWR oil pan, and an optima redtop along with the stuff ur already planning. The last thing u want is that plastic pos raditor cracking and overheating that exspensive ass motor.
that's what im doing, research right now, but if you look at my cardomain website 2nd page at the bottom you can see the pictures of the turbo and radiator fans clearance. without the radiator it's 4" between the frame and the turbo but i don't know what radiator to buy or fans... everything you said its already ordered... yellow top optima battery since i have lots of amps and speakers... thanx to TBK which i paid them to put an aluminun radiator and good fans, they putted these cheese oem one with cheese fans and kept you know what from me...
GTSPEC 4 Point Ladder Bar
GTSPEC Front Lower Tie Brace
GTSPEC Rear Re-inforcement V Brace
GTSPEC Partial Trunk Cage
Optima Yellow Top Battery
Samco Radiator Hose Kit
Gold Plated Rockford Fosgate Battery Terminals
already on its way to be installed..
AWR Oil Pan: Pending for price and availability
Clutch im still finding out specs of what i'll need
Rotora Big Brake Kit in Red, Still Waiting for Price and availability
Quife LSD with Bolts Kit, Im Still looking for the cheapest place i can buy it.
The PWR is nice and slim, won't cause any clearance issues. Go with some SPAL or other high quality slim fans. I am running a single 12" on the motor side, and a single 9" on the front (condenser) side. Works good for me even here in the desert during summer.
I am curious - I think you said you had a 3inch exhuast or slighty bigger
how are you going to install a GTSPEC 4 Point Ladder Bar???
I would like to see pics after you install...
Quife LSD with Bolts Kit, Im Still looking for the cheapest place i can buy it.[/QUOTE]
i have without the radiator 4" between the frame of the car to the turbo.
look at the clearance i have with these cheese rad and fans tbk putted after me paying for a full aluminum one with good fans.
also check out the rad brackets, do they work for the PWR Rad ? what about the bottom right hose position ? does it match the PWR ?
You should be just fine with those fans and the PWR. The brackets will work fine too, and the hose inlet/outlet are both in the same spots.
What brand are they? If you know that, you can look up their CFM rating. They might be better than you think.
nah men. they suck.. i think tbk bought them at a flea market. they suck no doubt. also they are like 8" each... there is no brand or model on them.. i need something better that goes along with a good Rad...
these is was im thinking of getting, what do you guys think ? will it fit and work good ?
AWR Full Radiator: Protege 95- 03 Our Price: $499.00
AWR Dual Fan Shroud Assembly: Protege 99-03 Our Price: $375.00
I work as a graphic designer and I'm training to become a Commercial Pilot...
Edit: Unless you meant the OP.
I did mean the OP but its all good!
i just thought i read that he said he is not made of money somewhere yet he is ordering tons of parts all of the time!
Status
