lil_red_wagon
- lil white p5
i'm in on this one. i want to do it for the same reason that i have done most things in my life; because it has been said that we can't.
So is it me or are more and more people going NA in the forums.......I keep seeing threads pop up. You have started something LordWorm.
(rockon)viva la revolucion(rockon)
Maybe we should get Leader board of the Progress those who are trying this.
Here use this as template
MakeMeGoFast.......2.5KL........0whp........"link to build thread"
What about swapping the 2.3L into the protege with a stand alone and ITBs. I'd say that should yield about 175-180. Add on to that the standard bolt ons and a port and polish with a good valve job and it should be pretty close to 200 if not over. All I have to do is rob a bank now....
How about the 2.3L from the Mazda3. How feasible would that be?
I thought thats what we were talking about?
Its feasable - the engine should physically fit - obviously custom mounts would need to be fabricated, some sort of management would be needed, and lots of custom wiring jobs to get the dash board work (this is going to be a problem if you go with any motor that wasn't in the car originally, the stock tacho utilizes a signal from the FP/FS ecu....)
Yes its feasable
yes it would be a reasonable engine to select
~230whp would be needed to cross the line first, unless you overbore it for more displacement then the target goes up.
very expensive engine choice though
if swapping is what you wanna do, the 2.5L KLZE would be my choice, because:
its been done before
the motors are not that expensive
and making the power wouldn't be that much of a push...
oh, and its been done before
if enough people were to go for this swap, we could get some really interesting debates and discussions about the best way to do the job.....
is there anyone in these forums that has done it before... bbecause i was trying to contact some people who have done it....
- Complete V6 engine and transmission with the half-shaft(or joint shaft?) plus uncut wiring harness, ECU and VAF(airflow sensor)
- Radiator and piping, either a MX-6 one or our custom aluminium V6 radiator for Protege(made by Ron Davis). If you use a MX-6 rad, you'll need to make some brackets. Our V6 rad fit bolt-on.
Everything fits bolt-on, you'll need to adapt the wiring to the dash harness and fuse box. You'll also need to adapt fuel line and exhaust. It's all pretty easy.
Two things won't work or do strange things, the tach and the temp gauge, so get after-market ones.
A while back I was in Contact with DOMSPUN(has performed a few swaps). This is basically what is needed. The most important thing is that Mechanically its a direct swap. By direct I mean No custom parts, well almost none. Obviously beefed up parts may be in order, is 250whp is the goal in mind.
Also keep in mind this is the basic List of things needed. He didnt go into complete detail as the list was in french and at the time he did not feel like translating.
