whered ya get it....its still bleeding off metered air....but its such a small amount im not sure if it matters
Its no different for those who have the ATP BCD to bleed pressure from the MAP sensor. Those guys don't seem to have a problem. I think its just too small of an amount to really make a difference.
should be installing the corksport DP tonight too! will let you know how that turns out as well.
No, the ECU/FBC cannot "pull boost". The ECU can only increase the boost pressure by opening the solenoid valve.
Basically what you are doing is increasing the minimum boost pressure which is normally set by the wastegate actuator when the solenoid valve is closed.
It works great! still hitting consistent boost of 15-16 psi in 1st -2nd and 16-17psi in the rest of the gears. Best mod so far!! should be installing the corksport DP tonight too! will let you know how that turns out as well.
Well Hell Man! I just found out this weekend that mine will do that(And Hold). Why do you need that?
Like this dude on YouTube bragging about his $640 Standback and that's all his is doing. What a waist!
Big fat guy, hunh? People like that should not be posting vids on YouTube, Standback or no.
car still runs bad ass, hits consistant boost of 17psi. yes the DP is installed, and everything is fine i dynoed 270whp and 310wtq with this set up!
