I'd like to get mine pulled out soon to do the clutch/flywheel/welded LSD but I think she's parked until next spring. Just gave her her last cleaning until winter is gone!
tore down my intake piping and IC it fix the two bolts on the bottom of the rad that hold the IC whose heads broke right off during the IC install but was rushed to get it in so the g/f wouldn't catch me buying more car parts LOL
Earlier I installed the Progress rear sway bar. I thought the install was going to easy and what do you know. The brackets that hold the bushing didn't line up with the holes, they were smaller. So finding that out, another forum member and I went to AutoZone and got the Energy Suspension 7/8" greaseable bushing that came with the brackets and just used that. I also had to use P5 endlinks since the ends of the rear sway bar was hitting the lower control arm. But after the testdrive, this 22mm sway feels way nicer then the stock Racing Beat one.
Oh yeah, the nut that holds one of the screws on the rear crossmember? decided to snap itself off. Pretty wack because I look at the nut and it was tack welded like out bad LSD.
that happens due to the load and every car is assembled that way as far as nuts welded to crossmembers and such. All four of mine are gone and I replaced with just a through bolt and nut on the outside of the member.
Yeah dude, it was the gayest s*** ever. But its over now and I'm happy.
Getting parts ready for the oil filter relocation and gauge installation. The relocation kit is going to make gauge sending unit installation a breeze. I just have to make sure I get the right sized fittings.
I never got overcharged...its just become annoying lol. I have to go buy my own oil first (mobil 1) and then go to this drive in/out joint. They only charge me $14 since i bring my own oil but i figured this time I'd spend the $5 on the oil filter wrench instead and do both cars myself from now on...
I just have to remember to take the oil to the drop off site and not let it pile up in the garage lol...I still have my gear oil sitting in there from 4 months ago.
i changed the oil too
after going to a few places and being overcharged (50$+) i decided to change it myself.
and it took me no more than 15 minutes
so glad i did!
Fixed a coupler on the turbo end of the hotpipe in the middle of the street this morning....damn these couplers are sh*t
ya, after finishing and cleaning up, i never feel like going back to the shop to dump the oil
i hav had pails of oil in my house for years...just being lazy
How often do you guys change oil? I'm on the twice a year plan, which ends up being about every 6000 miles. I should probably change it more often, but I only autocrossed three times this season. Next year I foresee a change before, halfway through, and after the auto-x season.
Call me neurotic, but I use Mobil1 5w30 every 3k miles...and I've been doing it myself ever since my warranty expired. I've always done my own maintenance on all my cars unless the car was under warranty.
