Worlds Biggest Idiot! Me!!
SPEEDYONE
2007 MazdaSpeed3
So yea i am so pissed off righthought id post this to help people out as recently wev had quite a few people having problems with bios
all the beep codes are different depending of who makes the bios , but here are some of the more common ones
What is a BIOS Beep Code?
When you power on a computer the BIOS immediately takes control of the computer and performs the P.O.S.T (Power On Self Test). At the end of the POST the computer will play an audible 'BEEP' through either the PC's internal speaker of through speakers attached to the sound card (if you have a built-in sound chip). If the POST completed successfully without detecting any problems with then system will play a single short beep to let you know the test is complete and the computer will continue to startup and load the operating system.
If during the POST the BIOS detects a problem it will normally display a visual error message on the monitor explaining what the problem is. However, if a problem is detected before the BIOS initializes the video card, or a video card is not present or not detected then the BIOS will play several 'BEEPS' through the speaker to let you know there is a problem. Depending on the type of the BIOS you have the BIOS may play beeps in a specific pattern to indicate what the problem is, or play the same beep a number of times indicating the problem. It is very important that you pay close attention to the number and/or pattern of the beeps your computer plays on startup.
Below is a table of the most common AMI, Phoenix and Award BIOS beep codes.
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video cardthought id post this to help people out as recently wev had quite a few people having problems with bios
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card get fixed. Any ideas?
that sucks man. Someone opened their door on mine and I have a small ding around the gas tank. Sucks :(. This type of stuff is going to happen I guess. I have the same color as your.s
what i would do is get some clamp pliers or something and bend it back as much as possible...then it would need sanding and paint and bondo to even it out. try going to a paint shop and see how much it cost..(ghey)
What about if i get a piece of wood, put it behind the door flush to the bend. Take a nice hammer or something and tap that thing??? I don't want to **** up the paint and have it chip off. But yea going to a paint shop/body shop sounds like a good idea. Arghhhhhh i knew i should of gotten lambo doors
either way the finish is gonna be ****** up...ur gona have to bend it or beat it back to place...paint shop will do the same and then jsut finish it up and even s*** out
I would not **** with it with pliers or anything..you'll just dig yourself deeper in a hole. Go to a paint shop and have them fix that!
For reference sake, if you are going to door ding another Mazda especially and not leave your info. Do not post it on a forum, moreover do not describe the car you did it too. Karma have it the Tribute guy will be posting on here shortly. More importantly, try and change the world if you ding someonelses car own up too it. I know no one else does thats how come we all have unfixed dings but its gotta start somewhere.
QFT definitely a wrong move. I have a couple of dents on my MSP from people that do s*** like this...
So yea i am so pissed off right now. I was in a parking garage going to eat so food with some buddys everything was going fine.
I found myself a great spot no worries from dings and what not. The wind was kicking tonight and was blowing right in the garage so as soon as i opened my door a tad not even an inch....
It happened, the door flung open at breakneck speed and slammed into the car next to me. Someones Mazda Tribute sorry, i bent the edge of my door like a 3 inch section from hitting a fender flair of the truck. I have no idea what to do, there is no paint damage and the door can close fine but it is awfully ugly and has to get fixed. Any ideas?
Relax, Relax there was no ding on the Tribute. Nor was there any dent it was the damn piece of hard plastic trim around the wheels.
I went to the dealer today after school to see what they could do for me. The guy down at the place was very nice and pulled the dent out for nothing, and even gave me a bottle of touch up paint for free. SO, i kindly slipped him a Jackson and asked him how much would it cost to make it look like new. He gave me a quote of 350 to 450 so fix it all up. I'm pretty anal about this car and i think I'm just gonna have them fix it up. By pulling it out you ant really tell anything was there, but i can.
I was under the assumption you did not cause any damage to the other vehicle, otherwise you probably would not have been posting here, so no worries. I know others that thought you left without a note were probably just posting based on their experiences with dings being left in their cars, so it's cool you cleared that up. Looks damn good to me based on the pics, but that is sometimes deceiving. I am very anal with stuff like that as well, but save the $300-$400 for school, and if it still bothers you in a few months, get it fixed. My guess is you will forget about it by that time and save some cash in the process.
