GullyBoy21
HOW DO I MAKE THE FOG LIGHT COME ON WITH THE PARKING LIGHT?(shrug)
easy, tap the red wire to the battery, and the white wire to the switch wire that turns on the parking light. use a test light.
bump-ola
Well my car has been at the dealer for over a week now for them to fix the rims and dash that they scratched. When I get it back or if I get it back I will work on this and post pics and dirrections. Don't expect anything till late next week as I know the car will not be back till at the earliest monday. Till then you can figure it out yourself or wait patiently on yer bum.
I know of three methods to get independant fogs.
Method one: removes the fog relay in the engine compartment fuse box and connects it to a different spot in the fuse box. You then run a wire through the firewall and tap the wire in the steering column. Result, fogs come on whenever the switch is on, and the ignition is hot.
Method two: only works on 3's with halogen headlights as the HIDs are wired differently. Involves cutting three wires above the PJB inside the cabin, connecting two of them together, and connecting the third to a signal wire. Depending on which wire you choose to tap for the signal the fogs will either be hot anytime the ignition is hot, or whenever the parking lights are on.
Method three: removes the fog relay in the engine compartment fuse box. A single wire is run from one of the positions the relay was plugged in to another part of the fusebox. Result, the fogs come on whenever the ignition is hot and remain on for ~10 seconds after the car is turned off. The OEM fog switch has no control over the fogs.
do you have more info on any one of these 3 methods, as any will work for me. More specifically, cut wire A, tap into wire B, cap off wire C, etc?
I'm interested in 3....seems to be a bit easier than the other two
that one is super easy but it takes away your ability to have the fogs off any time the car is running. Both 1&2 still let you control them with the switch.
which would be nice....I just can't think of a time when I wouldn't want the fogs on (I don't do any drive bys or late night stalking). Of course, as soon as I do I one of my peeps will start frontin and that special someone will stop answering my calls.
Wow, thats pretty interesting. I might have to try this one out![]()
