Wanted to see how much the car was dynoing stock before I put on some mods. These two were the best of 4 pulls. The first run I did (which is out of order on the dyno sheet) we had a small fan blowing on the front of the car pointed closer to the radiator.
The best run I had was when we put the fan on a box and had the air come in through the air ducts to the intercooler. We had lower intake temps and 10 more whp and tq.
The hood was closed each time, and all pulls were done in 4th. As you can see the A/F readings are under what his meter would read(eek2)... Right past 4k rpms the A/F went below 10.1
Sorry about the pic my scanner is broke so I took pics of the sheet.
The other two pulls that I did were right after the good pulls and the intercooler was heat soaked on those. They were about 30 to 40 whp and tq lower.
