New Wheels/Springs on MS3
I just put the springs on and the ride is ok,I still believe a better shock would compliment the springs though.
CaptainGJ,luv the wheels any rubbing with the wheels or with passengers in the back??
Do you think a set of 225/40/18 rubber would squeeze under there or will you have to stick with the factory 215/45/18 for ever ???
Im really liking the RM and OZ wheel recipe.
looks tight, the wheels look really good with the color of the car, hey "funkyman" you got the turbo emblem from a beetle i got one from a 911 turbo in the same place its3times bigger
I've had no rubbing at all and I have hit some BIG dips in the road at fairly high speeds. I'm not sure if 225's would fit. As it is right now the 215's sit VERY close to the fender well in the rear, I think 225's may rub in the back, but I'm not 100% on that. I also have the camber links installed, so that may have to be taken into account as well.
