I can hear my turbo? also I can hear a loud bov. but those are for a dfferent reason.
If you want to "improve the speed of your protege speed" there is a lot you have to do. First you should know that what companies claim for HP gains never happen. second hp gains from bolt-ons are not linear. third the first few mod you should think about are 1. change out the exhaust as it is pretty restritive, 2. Boost controller, 3. SAFC/injectors, 4. FMIC, 5. Injen intake when it comes out. That should help you get some "speed".
If you want to go crazy you could have a custom made down pipe, rebored throttle body, low compression forged pistons, light weight flywheel, new camshaft, upgrade brakes (if you cant stop why go fast), stand alone fuel management system, cam gears, billet Connecting Rods, Flexible Polyurethane Solid engine mounts, Ignition wires, short throw shifter kit, Walbro In-Tank Fuel Pumps, larger turbo, better Intake Manifold, port and polished, and some other thing i left out and you should have that "speed" you want.
This car was not meant for speed but for handling.
