Mazdaspeed Protege stalls after acceleration and putting in neutral
skilletrx
Nemo0o
Hi all - hoping someone can help me with some ideas. All I have modded is an Injen intake. After heavy acceleration (WOT here you can hear the turkey) if I throw the car to neutral, the RPMs will drop down to 0 where it may/may not stall out. Any ideas on what to look for? TIA!
Try cleaning the MAF and looking for vacuum leaks. Reset the computer after you do this
Check your neutral switch.
On my 5-speed P5, the computer needs to know when I'm in neutral so it can turn on the IAC to keep idle speed.
If I'm in gear with 0% throttle, the fuel injectors are shut off.
I'm not sure if that applies to the Mazdaspeed or an automatic though??
