Hey so I just finished my swap. But I am not sure where to hook up the turbo actuator, I swapped a msp engine and transmission into my p5. Where do I run that line to?
To the intake manifold. You can use a T fitting to tap into an existing vacuum line. Do not drive without this line hooked up or you will blow up your motor as the wastegate will not be opening and boost will climb over intended levels
You will want to hook up boost gauge and bypass or blow off valve to the intake manifold as well. You can buy vacuum line for hooking up these devices from most part stores.
