Hi All,
For sale is a huge pile of mostly OEM new old stock parts for Mazda 5 and Mazda 3 cars. I sold my car and have this sitting in my basement.
Would like to sell as a group. 400$ shipped to your door by UPS ground in continental US. Payment by PayPal good and services.
Located in CT if local pickup. For local pick up I also have core oem parts from Mazda 5 if needed - axles and front strut and springs assemblies.
Thank you!
Here is a description of parts:
3x quart bottles of OEM M5 Transmission fluid 0000-77-112E-01
2x carquest oil filters R85348MP
2x Timken front wheel bearings WB000028
2x Timken retention rings for front wheel bearings RET166
1x OEM lug nut D651-33-042A
1 each of transmission pan gasket: fuel-pro tos18731; ntb transmission gasket
1x OEM water pump 1F70-15-100
1x OEM transmission filter FNC-21-500A with o-ring 9954-10-2206
1x OEM serpantine belt L372-15-909A-9U
1x OEM AC belt LF50-15-908B
1x OEM water pump gasket LF01-15-116A
3x OEM water pump bolts 9XF0-02-217L
1x OEM thermostat LF70-15-170
1x OEM thermostat gasket LF03-15-165A
1x OEM gasket S210-15-204
2x OEM thermostat bolts 9XG1-67-357L
1x OEM pulley LF50-15-131
1x DAYCO pulley tensioner 89015
1x gasket LF1F-15-169
1x OEM hose LFB7-15-186C
1x OEM hose LFB7-15-183A
1x OEM hose L3G6-15-260A
1x OEM hose LFB7-15-381B
1x OEM hose LFB7-15-185B
1x OEM clamp 9928-62-500P
2x OEM fasteners GD7A-50-EA1
1x OEM cover CC33-55-225
1x OEM fastener 1395-68-676
4x OEM used wheel lugs in great shape
13x OEM aluminum oil and transmission plug o-rings 9956-41-400
1x New FUMOTO oil drain valve F1065W 14mm-1.5 fits Mazda 5
1x old OEM touch up paint code 32 (gray metallic) never used, don’t know if it’s still good
1x Alloy wheels repair kit, old never used I don’t know if it’s still good
Thank you!
