- Plano, Texas, USA
ATF is different from engine oil in its operational environment. ATF is running in a sealed environment hence the service life is much longer than the engine oil. Car manufactures claim the ATF is lifetime, but they only support their claim for as long as the powertrain warranty lasts. People also send in the used ATF for UOA and those labs will tell you the condition of the fluid. Since Mazda doesn’t give a replacement schedule on ATF, people are change it based on their own experience for frequencies. I myself would change the ATF based on the maintenance schedule from some of my old cars such as my 1998 Honda CR-V and the manual says 75,000 miles. I’ll do it earlier than that though and my CX-5 doesn’t do any towing.Honest question here. I'm new to this forum, but had my 2016.5 Mazda CX-5 AWD Grand Touring for over a year now..bought used. Has 110,000 miles, no issues.
I'm ready to change rear diff and transaxle oil, which I'll do myself. I'm hesitant about the transmission oil though, if dealers and mazda don't recommend it.
If some of you are so confident with it's benefits, why wait until the warranty passes? There has to be a reason why it's not recommended? Oil obviously doesn't last forever, but perhaps they think it will last 300k miles?
Why should I trust mechanics and backyard mechanics over Mazda's engineers?
If you don’t want to drop the pan replacing the filter cartridge inside, you can do a simple ATF drain&fill 3 times which is almost as difficult as changing the engine oil. Make sure to use Mazda ATF FZ.
