SplitSecond Software
http://www.splitsec.com/software/SETUP.EXE
SplitSecond PSC1 Map Library
Installation Instructions
Provided by kicker22705
Frequently Asked Questions
Provided by CasopoliS
Boosting Safe:
07psi - Stock
08psi - Catback exhaust, CAI, stage colder plugs
09psi - All the above, plus hardpipes, smic, and j-pipe replacement
10psi - All the above plus FMIC, full turbo back exhaust, some form of fuel management (AFC for example)
These have been tested by DSMConvert
14psi - All the above plus 440cc injectors and wideband.
Running by few users
Map 1: SuperMapStock
Created by DSMConvert
Best map to date.
Map 2: FMICMAP
Few users had problems with this map.
Map 3: 440cc Injectors Map
Created by Blue_speed
Custom Map (Updated Feb 23, 2006)
Map 4: Winter FMIC Map
Created by jeffmsp
For low temp use.
Map 5: Mazdaspeed 14psi map
Created by kicker22705
Custom Map added safety after 5500 rpms, 440cc injectors needed.
For More Maps, see the following posts:
http://www.msprotege.com/forum/showpost.php?p=4130269&postcount=606
http://www.msprotege.com/forum/showpost.php?p=2310037&postcount=111
http://www.msprotege.com/forum/showpost.php?p=3633308&postcount=426
http://www.msprotege.com/forum/showpost.php?p=3638037&postcount=437
http://www.msprotege.com/forum/showpost.php?p=3678504&postcount=451
http://www.msprotege.com/forum/showpost.php?p=3913592&postcount=499
http://www.msprotege.com/forum/showpost.php?p=4741509&postcount=1024
http://www.msprotege.com/forum/showpost.php?p=4355734&postcount=786
http://www.msprotege.com/forum/showpost.php?p=4355745&postcount=787
http://www.msprotege.com/forum/showpost.php?p=4917557&postcount=1091
http://www.msprotege.com/forum/showpost.php?p=5107118&postcount=1241
http://www.msprotege.com/forum/showpost.php?p=4749352&postcount=1034
http://www.mazdas247.com/forum/showpost.php?p=5213433&postcount=1489
Also, here are links to posts with a couple of quick reference guides that are very helpful
YOUTUNE ARTICLE
AUX INPUT SETUP
Boosting Safe:
07psi - Stock
Best map to date.
Map 2: FMICMAP
Created by jeffmsp
For low temp use.
YOUTUNE ARTICLE
AUX INPUT SETUP
