Will these rims fit a 2010 Mazda 3 GT
WagonMan
2010 Audi S4
I have a set of Weds Sport SA-70 with the following specs:
18x8
Offset +50
5 - 114
I used these on my 07 MS3 and have had them sitting around for a couple of years.
My question is, will these fit on the 2010 Mazda 3 GT that my brother in law just purchased?
And what would be the range of tire sizes that should work on them.
I've had these sitting around for a couple of years, and would love it if I could give them to someone in the family to use.
Thanks!
it will fit just fine. it has the same spec as the rx8 wheels. and lot of 2nd ms3 owners have them
225/45R18 would be a good tire size. 235/40R18 if you want a little wider and you can bump up the sidewall to 50 if you want also. Are you lowered? That would be the determining factor on the sidewall.
