Is it possible with a auto trans?
Yes, it is very possible.
What is the best kit?
My biased answer will be the Flyin Miata / BEGI kit
. Unbiased I would still reccomend it based on the extensive testing and continued tweaking of this kit.
Is there any extra parts to buy (outside of the kit)?
No. The kit is complete with all piping, intercooler, boost gauge, turbo, oil lines, etc.
Can I do this at home?
Are you a skilled or semi skilled mechanic? The directions are very good, but this is not a one hour job. I would estimate between 8 to 12 hours of work if done on your own. A shop charges between 500 to 800 dollars labor as a ballpark figure.
How great is the out come?
Incredible. Just go to the Forced Induction forum and read some 'kill' stories. Or check FMProtege.com for dyno results and impressions. At six pounds of boost, there is an increase of about 70 horsepower. You will notice this!
I just want to add that extra boost to my car is this the best way?
Touchy subject. There are those who prefer doing an "NA" route with high compression pistons, camshafts, rods, rings, reinforced internals, etc etc - but in all honesty the power / cost ratio is better with a turbo. You get more "boost for the buck" going turbo. You also don't have to tear the engine down like you would with the so called "NA route". I don't think I need to stress the superiority of turbo over NOS either - there are enough horror stories on this forum about the dangers of NOS to convince you of that.
Good luck!!!
