smoke after hard acceleratino
2088 MSP
PS!
Potential Scammer!
03.5 silver MSP
so yeah I just put on a new valve cover, which really went with no complications, but now it smokes after hard acceleration. as in I can go 2nd full boost, 3rd full boost, 4th boost, then u know shift into 5th and let off the throttle and a big plume of smoke suddenly emerges behind me. The strangest thing is there is absolutely no smoke during the actual accelerations while in boost or not. and literally the only thing that changed between me smoking and running perfectly before is the swapped valve cover. WTF?
I sort of used this opportunity to smoke out a couple of Priuses already too! lol
i'm thinking I blocked that crank case vent port thus oil gets pushed into the cylinders past the rings?!
dam, 50 views and no opinions at all? its good thing I'm a pretty good mechanic myself, i'd like to modify that previous post. It WAS the blocked crank vent port, well actually the port that u put a little vent filter on itself had some sort of silicone/rubber s*** in it, apparently the previous owner of the valve cover stuffed some s*** in it. and the oil was getting pushed past the valve seals down into the combustion chamber.
