MSP OEM Enkei Rims - Center Cap Removal
Hank3
Asian Persuasion <><
Contributor
2010 Mazda5 GT
Just had a really quick question. I got a set of MSP rims off craigslist that I want to get PC or repainted. Do the center caps simply pop like most rims or do I need to undo each allen bolt? Are they faux allen bolts? Haven't really looked too close yet.
Is there an easy way to tell which 2 of the 6 in total are the ones to loosen?
look on the back of the wheel, the two that need to be loosened will have threads....flip wheel back over and see where the threads correspond and vwalah
Be careful removing the T-27 Torx screws, they are tight in there and can snap. Use blue loctite on them when you reinstall so you don't lose the caps.
