Looking for a part number for a plastic bit inside the rear door.
Protege5 2003
When the trim panel assembly is removed from a rear door, which looks something like this:
http://onlinemazdaparts.com/parts/2...iteid=214264&vehicleid=138154&diagram=5416549
there are two nylon retaining clips that hold it in place by being pushed in along the back edge of the door. One is low and the other about 1/3 down from the top of the trim panel. The top one goes in roughly where "5" in that diagram is pointed. They go through the trim panel and into a sort of white plastic spacer that is inside the door, behind the trim panel. If you pull the clip out (it removes easily) you can see some of the white part of this spacer. That spacer is basically a plastic L bracket which has two "legs" that go into the metal part of the door. On my daughter's car the upper spacer has both legs snapped off, so it won't hold the upper rear part of the left rear door trim panel in place.
Anybody know what that white spacer's part number is?
The only candidate I see on that page is B25D68403A, and the price is only $1.71, which seems awfully low for a mazda piece of that size. (The spacer is several inches long.) It is roughly the right shape though.
The diagram for the inside of the door is here:
http://onlinemazdaparts.com/parts/2...iteid=214264&vehicleid=138154&diagram=5416542
and I don't see that part there either. The spacer's legs go through the water shield ("14"), so it should be on the trim side of that drawing, but there is nothing there that resembles it.
I ordered one (at that price being wrong wouldn't be too painful) and B25D68403A is the right piece. Not that you could tell from the cruddy drawing in the parts diagram!
