Boost gauge.
i'll help, but i must warn you i take my time. i hate making mistakes. my girlfriend says i have OCD :D what all do you want to install, how do you want to do it drill, tape???
RX-KEVIN said:
plus you could have drilled a hole in the stock a pillar and run the hose a little neater
HAHA Ive heard that before. oh yeah when i was called rice cause i didnt not naming and names (bitchass in dallas) lol
Well
I could say, "At least my install doesn't look as bad as Chris's."
:eek:
Hey Chris how ya been? Long time no see.
Hey i orederd a boost gauge too and a pilar pod where did you run your gauge wire thriough the door. And where did you splice into the vacum line off the bov?
Here
The hardest part was making the opening in the foam grommet attached to the firewall under the washer motor.
I used a long thin flathead about 12'' in length and pushed it through the grommet from the inside being careful not to harm any of the wires going through it.
I then took a straightened out close hanger and inserted the tip of the hanger into the end of the 1/8'' hose and pushed the tip with the hose attached through the grommet opening while I was laying in the floor board. Worked like a champ.
It has avery tight seal around the hose and there was a perfect amount of hose to reach just the right spot on the A-pillar.
The only problem I had was kinking the hose when I pulled it through and then going WHY THE HECK IS MY GAUGE NOT WORKING! Doh! Kinked hose all better now.
I dont have the light hooked up at the moment but it is a very simple task to do and I will install it this weekend.
All in all it wasnt too bad. I did read an install guide one of the members put togther.
Yes here it is wonderful work.
http://homepage.myeastern.com/~jesser/"
