Battery Light ON but Alternator is Charging?
Had the codes checked today, no IAT code. I believe the pins on the connector were loose, so I bent them back and its good to go.
Having the SAME/SIMILAR problem. Which pins on which connector are you referring to?
MAF? alternator? PCM? Something else?
Did you ever fix the problem? Did it ever come back?
Similar Threads and Articles
