Audio Dummy's Questions-I need all the help i can get.
  • Thread starter Thread starter 1flycostarican
  • Start date Start date
1
1flycostarican
I want to put in my Kenwood 600 watt amp and my 2 12'' Audiobahn subs in my car, can i use the stock headunit to hook them up? Are they preamped? Will it sound good? How hard is it to hide the wires? How hard is it to do all this install all this? How much does the wiring cost? and finally........does the bass sound like suv bass? cause i had a 94mx6 pior to the protege5 i have now and i hate trunk bass......aight thanks for the help guys i neeeded it.......1
What is the Kenwood amp model number and the audiobahns model number?
The radio is not preamped you will need a line output converter unless the amp has speaker level inputs. They are around $20
The amps true power will determine the wiring used. 8 guage kits cost $30, 4 guage kits cost $50.
You'll need RCA's also if the amp dosn't have speaker inputs, $20.
Speaker wire may be about $5-$10
SUV bass.
Takes a professional anywhere from 2-4 hours to do this. A first timer can take 3 days and end up with a dead radio.
