@#$%^@#$$% z919 radio@##$%%#@
i get to the point where it shows me how many tracks there are so far and how much space i used and whats left. i have like 121 tracks but when it time to burn a screen pops up and says that there is an uknown error and that i need to contact musicmatch techinical support. man ive been messing with this burner for 4 dayz now and all i have to show are some messed up cdz that were recorded wrong and that only have like 15 songs on them instead of the 100'z i want. i have the musicmatch jukebox with the nero 5 and nothing is working right with me please give more detail as far as what i am doing wrong and what might be wrong. as far as making them mp3z i thought they were already and if not how do i make them into mp3 format???????? :confused: :confused: :confused: :confused: :confused: :confused: :confused: :p :confused: :confused: :confused:
I'll take a better look when I get home about 5:00 EST. I wish I could give you some more help, but I need the program in front of me to really figure out, plus I need to do some work at some point and time while I am here... hehe
Originally posted by kep0:
[QB]ok check it out...to make a data cd, first you need mp3s (hence the car name). all you have to do is first arrange the music in a folder on your hard drive. make sure theres no spaces, replace spaces with underscores ( _ ) cause the 919 wont read them. those with the 828 have the benefit of id3 tags (i wont bother explaining those...they get complicated and tedious). you can arrange them in different ways. ill explain my way, as it is the most organized wayi can think of.
I can get the z919 to do spaces just fine! I use Nero 5, and do ISO Level 2 (32 chars per filename), and ASCII Character set, Joliet mode... Never had a problem with spaces!
Chris
There's a coll little freeware called 4mp3. I use it to add or edit the id tag. I can use spaces, special caracters and even letters with accents like and . Then i burn in joliet mode and my z828 has no problems reading them. ;)
Hey man, whenever I try to install my Roxio burning program, whenever i start it up, i get a DLL error too! i'm using win98, you?
Well,I ended up using Nero instead, but .. yeah, I thought it was a problem with my computer.
