MS MSP said:you need the S-pipe?
I have a spare, PM me with an offer.
blthlt said:you mean from the turbo to the resonator or just from the turbo to the springs?
Are you out of warranty?Sighter said:There are two cast pieces. One from the turbo down the front of the car (don't need that one) the other is the j-pipe that is a 3 bolt flange in front and two bolt spring loaded flange at the rear (need that piece).
The broken piece is cast iron and about 12" long and has the heat shileds bolted on it top and bottom.
My turbo exhaust flange housing, heat shields, cats and s-pipe are all fine.
ForceFed said:Are you out of warranty?
If not....Then make the dealer replace it.That piece should never break being a cast piece....unless you abused it somehow?
