Wondering About something
Sefy
Protege 5, sunburst yellow, fully loaded
Im recently the proud owner of a 2003 protege 5 fully loaded with sunburst yellow, and ive had someone take off the dash part that houses the stock stereo system just to see what type of setup is there and how much work would be needed to change out the stereo or if it was even worth it to, but the person pulled it out too hard with the climate controls still attached, and when it was all put together, the ac button stopped working, and ive lost all my heat settings except vent and floors, and im wondering if this would be something easily fixed or if i should bring it to the nearest dealer to get fixed
check to see if everything in the back of it is still plugged in first off. Secondly you are going to need to check the cables and if they are still where they need to be. The first cable is to the right of your gas pedal the other cable is located behind the glove box
I was also wondering about if i swapped out my stock exhuast with something different would it screw up my emission censor?
And then go kick that person in the head!
as well as is it possible to turn a mazda protege 5 into an AWD
there are ways around your emissions. it all depends on what you replace. if you put a catless header on the car then yes you will need a fix for the sensor.
It is possible to do a AWD P5. its possible to do anything with enough time an money. There is a euro spec AWD p5 but the AWD system was fairly weak and its going to be pointless in a NA p5 neway
Wow, goes from simple climate control switches... To simple exhaust upgrades... to converting to AWD. Lol.
I know, seems threads are all over the place these days. Heaven forbid anybody try to find useful information later on.
Well, yeah, this one maybe but others that start off one way sure seem to stray in different directions pretty often these days.
