WIRERING A AMP AND SUB WITH EXISTTING WIRES
since some of u have put in aftermarket sterio systems including subs and amps...How did u do it wit the existing wires??..what wires did u get rid of and what were at use to u...was there a pre existing hole in the firewall to run the power wire to thte battery??...any one with info on the subjects get back to me asap....thanks...
If I remember right (from watching my roommate install all my stuff) - most of the factory wiring wasn't used. it's quality wasn't all that great. ran all new wires. there is an existing hole in the firewall through which most wiring will fit. i think all you have to do is push it through the existing grommet. hope this helps. good luck.
do not in any way use those exsisting wires. they are junk. they are basically speaker wires. just break down and buy the amp install kit
