Dino1956
Question: Do codes come back after you disconnect battery, even if you Fix the problem. I know the code will still be in History, But if you fix the problem, then diconnect battery to shut off "Check Engine Light". Will the same code come back anyway since it was not cleared from the computer ? Thanks.
