I just noticed a strange issue with my '08 GT's AWD transmission. I am able to consistently duplicate the issue, so I'm thinking it's a programming issue. Can you guys check your vehicles, and tell me if they do the same?
When I gently slow down to make a stop, the transmission will downshift one step at a time, but always switches from 3rd gear to 1st. If I attempt to accelerate before making a full stop, at the point that it would be in 2nd gear, it slips slightly, then goes in 2nd gear and then goes. If I slow down too much, it will just go into 1st gear, and take off normally. If I don't slow down enough, it will take off in 3rd gear normally. I have to be the exact right speed. The correct speed is just a hair below the first line on the speedometer (10mph line I think).
So....do about 30 mph, slow down gently to a little below the first line on the speedo, then gently accelerate again. That should duplicate the problem if it is normal to this vehicle. Please help! let me know, I'm worried about it, I don't want transmission failure!
