Mazda3ofKent
- Mazda 3 5 door
why doses the 2.3 sit like that
goldwing2000 said:It's not the only car that's set up like that but first guess is that you don't have all the exhaust heat washing over the engine.
Also, it simplifies the exhaust system because you don't need a flex pipe.
It puts the intake manifold where it can get the most benefit from incoming cooler air.
I'm sure there are a host of good reasons but the real question is:
What difference does it make?
Here's a better question:
Why does Honda put their transverse engines in with the front of the engine on the driver's side instead of the passenger side like every other OEM?
It's just one of those cosmic rhetorical questions that will bug you to death but doesn't really matter much.
AzMz3 said:No flex pipe???? Are you sure about that????
trbomp5 said:Also Hondas are in there backwards because their motor turns backwards from all other motors. (I've had 3 hondas)
goldwing2000 said:Yeah... but why do the motors turn backwards? (scratch)
Got me, I heard once, but I cannot remember.goldwing2000 said:Yeah... but why do the motors turn backwards? (scratch)
This is from a Mazda3 press piece (but also applies to Mazda6 2.3l):Mazda3ofKent said:why doses the 2.3 sit like that
