Which wires to tap for lock and unlock? - SOLVED
Hi all. The original model of my CX-5's master window switch is the KF33-66 350. The side mirrors stopped working and I was unable to source a replacement with the same exact model. I ended up purchasing a KR11-66 350 instead. All pre-existing functions work, the only difference is that the KR11 comes with door lock/unlock buttons which I now would like to activate. Can anyone guide me through which pin outs do I need to tap into?
Thanks.
This has been resolved. Lurking through the forums I've found this link:
https://www.drive2.ru/l/529290330156040211
Credits to NewFate, and Google Translate. Took some bit of understanding because of how much Google Translate can go, but essentially the pin you want to tap into as mentioned in the post is 1E on the master power window switch.
This is showing as N/A or not used in the service manual. Next is pin 3F from the RCBM. I guess the last part that's being said is how he figured out not having to run the wires from the RCBM through the front door to activate the door lock switch. There's actually a wire from that RCBM pin that connects to the driver side door actuator lock assembly. That wire is shown below:
For testing purposes I just had the wire connect through temporarily. When it was successful, I salvaged an unused pin from another plug and used that to secure the additional wire. Works like a charm.
