Wheels and Tires for 2007 Mazda 3 GT
braxus
Just wondering about wheels and tire combos for a 2004-up Mazda 3 GT. Am I correct 16" is the smallest rim size you can put on a GT with the 2.3L engine? And for summers if I went 19" wheels, what is the max tire size one can put on the car? I was looking at a set of 245/30/19 tires, but not sure if those are too wide to fit. I suspect the 19" wheel will have a lower offset then the stock 52mm offset. Maybe closer to 40 or 45. Other possible tire sizes would be 215/35/19, 225/35/19, and 235/30/19. Which one is the widest you can go with?
Doesn't anyone here own a Mazda 3 (which is Mazda's most popular car at this time) and changed the wheels on it? (hand)
For sure the 16" steel winters is the smallest that will fit over the front brake calipers. I tried to mount a 15 - and it was an interference fit.
No idea about the max widths for 19"
I wouldn't put anything more than an 18 inch wheel. 18x9 would be a big wheel for the 3. Stick to a +45 offset at the lowest, anything less and you'll have some major fender cutting, pulling, rolling to do.
