Okay, a lot of wheel discussion goes right over my head, but maybe someone can help me figure this out.
First, I'm not interested in changing the handling of my car; I think Mazda did a great job and I don't want to mess it up. Basically, I've been looking at changing wheels to something lighter, but with the same offset, diameter, and width.
I know the stock offset is +55, but I also know that if you change the width of the wheel, the offset needs to change, too--if you want everything to stay roughly the same. Is there a way to figure out what the "correct" offset should be for a 7.5" wheel? An online calculator would be awesome!
Two related questions: How close is close enough when you're discussing offset? If I went with a wider wheel, what other considerations do I need to weigh?
Thanks!
Thanks!
