whats everyones boost spiking and holding???
im going to try it. and see what happens. im sure it will be fine with the 35 shot. a freind did almost 100 shot on a slightly modded srt-4 and he was fine. so a 35 wet shot should be more than safe.
as soon as i try it i will go to the dyno and do before and after with the 35 shot.
you do know that you will need to add a secondary fuel system dedicated to the "wet" nitrous right ??? a regular kit cant handle the 1600+psi our fuel system delivers.
yep i know that im just going to convert it to a 35 shot dry. it should still be fine being that our afs are in the 10 with the stock ecu settings.
my car is boosting lower now for some reason....
it will hit a spike to 16-17 and hold about 14psi.
same car, same mods, same boost gauge. it has been slightly lower than usual for about a week.
Lol, yeah I can hit like 11psi tops when its 110, and I can pull like 14 psi top at 92, and I can hit like 16 psi consistently in the 80s
