what kind of oil filter do u use??
TeamVP
03 MSP Titanium
I dropped my car off at the dealership because my engine had a little ticking noise. Well they told me it was because of the oil filter, something about the paper inside the Fram filter was not strong enough. They said with this car you should only use the mazda filter. I had never heard of that before and was wondering if anyone else has had the same problem? Also after they changed the oil and filter the tick was gone? the oil and filter were only at 2000 miles.
thanks for the help
never heard of that before unless it was a faulty filter. The filter must of restricted the flow of oil big time to your engine to make it tick. MAke sure you document that in case there is damage to your engine.
I use K&N
I have never heard of that either and yes i would document it for sure !
I use the mazda filters they sell in the parts department.
K&N
The one time I HAD to use FRAM was the worst ever experience. Car felt really bogged down and slow. Felt like the filter was not flowing enough.
i use fram....granted its a different type than you get off the shelf at autozone, get it through the sprint car team. still a fram none the less...no problems at all here.
edit: but k&n is a VERY nice filter...thats what i used to use.
what do u guys mean by document it? should i do that through my warrenty at the dealership or do i do something else?
I would have taken that old oil filter, kept it , and got a written report from the place that changed your oil. If you ran 2000 miles on a falty filter then Fram should pay for any damages that could occur. Watch for any smoke or metal chips in your engine. HEll you could have really screwed something up by not having enough oil. Not you, I mean the filters problem. IF you engine happens to blow up tommorrow then ou have no way of proving that it was a bad filter unless you document it.
Thats a good idea, but i just started driving my car and the ticking is back so i knew the dealership fed me aload of bulls***. Its going back there today.
does the MSP also have that vcts ticking thing? maybe its from that. Just a thought, not really sure. I use whatever filter Jiffy Lube puts in and yes I know I shouldnt use them, but no way was I gonna try changing my oil in the cold. I'll be doing the next one myself, most likely will be going K&N as well. BUT prior to the my 02 ES, I used to use FRAM on my 91 subaru legacy and never had a problem with it.
I use the OEM mazda.
FunkyBuddha said:
K&N
Is this a joke? :bs:
