what is the bolt pattern for a MSP?? and what size is good to go with??
JoeHoff04
Hey Guys im lookin to buy rims just need are bolt pattern, width of tire and a good idea of what size fits and rides good for a MSP??
5X114.3 +55offset stockers. I went to a 17x7.5 w/ 225/45r17 tires had to roll rear fenders. worth it, if you live somewhere warm get something sticky if not the gy f1 a/s are awesome!
^^ What offset?
To the OP, you can find this info in the protege sections. Tire and Fitment Guide.
I run 17 x 7.5 +50mm no fender rolling
17x7 mb weapons with a 42 or 43 offset. Had to roll the fenders but damn it looks good sitting flush with them
If you go for 7.5" wide rims the best offset to get is between +42 to +48, beware there still could be rubbing issue.
17X7.5" w/ 225/45r17 +45 offset rubbing. No more back seat. Although that could be due to suspension as well.
feel under the edge of the rear fender. you will feel a part that goes parallel to the ground. rolling the fender pushes that up into the body to clear it out of the way of the tire
18x8 rx-8 rims with 215/35r18 tires. Fenders had to be rolled and it barely fits dumped on Tein SS dampers. Any wider of a tire and it would rub for sure. I had K-sports before and I had to run wheel spacers to clear the suspension, it's fine with the teins though.
i'm on 16x7 +42 offset with 205/40/16's slammed on k-sports and i have no rubbing but i'm running -2 degrees camber in the rear and about -1.5 in the front.
New Threads
