What have you done to your MS3 today?
thats a long span for that mat'l, recc' you run a stiffing brace along the underside, storage shelf especially
doing that tonight.
and to go along with the thread....the 2x4s i will be using are in the ms3. all 4 pieces at 9ft each. i will probably never own a sedan again....sticking with a hatch
Called my local dealership and priced the cost of a spare key and how much it would be to get programmed..........45.65 for the key and 95 for the programming
Had new brake pads installed(front an rear),oil change/lube/filter(5W30 Castrol Syntec) and tire rotation done today. The pads were Hawk Ceramic and I had the rear brake rotors(Centric 120) replaced(all parts from Tire Rack).
Washed the car today in the 60 degree weather. Man oh man was it bad. Filthy, rail dust and all that s***. I can't wait for the spring.
Pics and all in my build thread.
Changed my oil and rotated my tires. Not quite as warm as yesterday but definitely not unpleasant.
And I got to try out my new creeper that I got for Christmas.
Ordered 2 replacement rear shocks for my BC Coilovers and a set of SPC rear camber arms today. Next week I will be ordering my DNP turbo manifold, and then after that, the autotech fuel pump internals. Time to get busy on the car again - 2011 was an "off year" for the speed, so I am getting busy this year. Getting the wheels powdercoated next month and hopefully getting my roof sprayed black as well. Things will be coming together quickly!
tore out my turbo for rebuild! :) "upgraded rebuild" ;) pickd up an accessport cheap with turbo inlet pipe. can't wait until nxt week! to put it all backtogether
Finally found some cheeeep tires to replace the very bald fire hawks on the front
used, but still with 40% tread
65 for the pair
toyo proxes RA-1
in 245/40
grip has improved somewhat (breakn)
Drove it to work, drove it to fetch dog drugs at lunch, drove it home. Riveting, I know. :)
Changed my plugs at 22k.
