I've got a weird suspension rattle that maybe someone can diagnose.
Occurs only when turning left and the suspension lifts on the left side. Sounds like it's a lower area:
The control arm and tie rod end are almost new, and show no looseness that I can find, including when I jacked up the car and moved everything. The swaybar end link is ok with no looseness or play.
The bolts on the control rod and tie rod end and balljoint are tight.
The car makes no noise if I bounce it up and down.
No noise if I jink left and right hard while driving
no noise if I go over a speed bump
no noise if one side goes over a speed bump
the only thing I haven't checked yet is the swaybar bushings, and I figure they'd make a noise if one side went over a bump.
Anybody know where I should look?
