boostisgood
- 1988 FC3S TII
general info for all:
No aftermarket part voids a warranty, unless it is directly related to the cause of the work.
Example 1: turbo timer on your car, and your radiator blows. The work WILL be covered.
Eample 2:boost controller on your car, you crank it to 12psi and blow a rod through your oil pan. better scrape your pennies together cause you voided the warranty by overboosting, thus causing the need for warranty work.
To get all the info you need for warranty claim protection goto http://www.enjoythedrive.com/san/. Here is info from Sema (Specialty equipment Market Association). Follow this link to learn more about SEMA, and the benefits it brings to us, the enthusiasts. http://www.sema.org/content/?id=7372
