Warning TWM Shifter & Cobb shift weight on Ebay
macguy
Just wanted to give everyone a heads up about these two listings:
http://cgi.ebay.com/ebaymotors/TWM-..._Accessories&hash=item2c54839178#ht_500wt_954
http://cgi.ebay.com/ebaymotors/Mazd..._Accessories&hash=item2c524764b3#ht_500wt_954
First one states it is a TWM shifter and it is not, it is a E4 Performance Shifter
The second claims to be a Cobb shift weight and it is again made by E4 Performance.
The seller, idj4uljdj is Matt from Debears2k. I had to go through Ebay to get my money back for the shifter (it came loose while driving, almost causing an accident). It was when this happened, I did more research and learned that it was not an original TWM as being advertised. The Shift weight I kept since it fit well and how much can be wrong with a piece of metal.
I had hoped that after my experience and starting a case with Ebay, the listing would be changed to reflect the actual item, but I checked today and the listings are still the same.
I would have posted this warning sooner, but I was waiting until my refund came through. I am in no way trashing E4 Performance, just want everyone to know what they are buying if they come across these listings.
just for this reason I have always ordered things directly from the vendors, most of them run sales from time to time which is just as good if not better then what you would find on eBay, plus most of them are willing to give you discounts if you just ask. Sorry to hear about your issue but we all live and learn.
