manotickdon
- Mazda3
I have an issue with my 06 M3 when after I remove the key, open the driver door and ensure lights are off that the warning beep is still on. Closing the door silences the beeping. The remote is inoperative as well. If I play with the switch cyclinder by stabbing the key in and out at the top portion then the warning beep disppears and the remote entry works again. It sounds like a key cyclinder problem, what do you think ?
