Hey guys, so I know my way around cars but I had a new one come up this evening.
I had the wife take the car in for new tires and an oil change this afternoon. When I got home I did my typical post-mechanic inspection. On my way back I was at a stop light and the car studdered really bad and nearly died, twice. When I pulled in the driveway I noticed an intermittent knocking coming from the motor. I let it run for a bit longer and noticed that there was not pattern to the knocking. Only that sometimes the car would shudder badly. It almost sounded like something was rattling around in the motor.
I pulled off the valve cover and did an inspection, my first thought was maybe a bad valve spring, but I couldn't see much. I pulled the spark plugs and noticed that the plug in the cylinder closest to the driver side had a very small gap. I also observed that the top of the plug looked very "beat up". I fixed the gap and put the valve cover back on. I started the car up and the same thing happened. So then I decided what the hell and gave it some gas to see if that had any affect on it. As luck would have it, it did. The rattling got louder/faster and then all the sudden went away.
I let the car idle back down and noticed it was idling poorly. I pulled the plug again to find that the gap and gotten smaller. Again I regapped it and the car seemed to run "ok". I took it for another test drive and when I got back it was surging again at idle. I suspect the plug has taken too much abuse and I'll replace it tomorrow evening.
The question is, what the heck happened? I am supposed to take this car from FL to VA in under two weeks and need to get a level of confidence back.
ANY help is appreciated!
