Turbohoses
Thank you for your patience.
Our test vehicle is completely stock and tested with our Aluminum Piping and stock boost.
The end results are as follows:
We were only able to run our test vehicle 4 times for each IC. We noticed by the third run the engine began to detonate, we believe this is partially due to the operating temp.
Baseline:
1.Turbohoses IC= 158.3hp/169.1ft. lbs tq.
OEM IC= 142.7/159 ft. lbs. tq.
Gain of 15.6 hp.
2. Turbohoses IC= 157hp/167.1 ft. lbs. tq.
OEM IC= 142.4/158.1 ft.lbs. tq.
-Break 2 minutes before next run on Turbohoses IC-
3. Turbohoses IC= 158.5hp/169.1 ft. lbs. tq
_Break 5 minutes before running OEM IC-
OEM IC= 140.7hp/ 152.9 ft. lbs. tq.
4. Turbohoses IC= 154.6hp/162.4 ft. lbs. tq.
OEM IC= 138.7hp/150.2ft. lbs. tq.
Note:
Turbohoses Ambient Air temp.= 87 deg.
OEM Ambient Air temp.= 83.5 deg.
Dynoing with the OEM IC resulted in hesitation on WOT.
OEM Intercooler Pipes: Unable to complete dyno run due to engine hesitation at WOT.
We also took a temperature reading comparing aluminum vs. steel piping using the stock IC.
Aluminum- 100-108dg. f.
Steel- 135-142 dg.f.
Thank you,
Turbohoses R&D
Baseline:
Gain of 15.6 hp.
Note:
Thank you,
Turbohoses R&D
