First let me begin by saying I love, love, love this mount.....the feedback you get as a driver with it installed is simply amazing.....My car has an AWR rear mount, and PG engine Damper kit also installed. I've already decided I think Im going to change the engine damper out for the AWR passenger mount and now Im thinking I may have to replace the TRZ mount as well...
You see I track my car (1/4 mile) as often as I can....As we all know the wheel hop this thing has stock is rediculous....and now that Im running the hypertech tune...GOOOOOOD LORD....So needless to say Im very happy I have the motor strapped down nice and tight inside the engine bay.......OR DO I?????......
You see while installing both the TRZ and engine damper I discovered to my extreme dislike that neither replaced the vertical bolts which supported the engine to the mount.....and what really upset me was theres not even a nut that you could install to keep the tranny and engine from litterally sliding down these bolts should the threads in the mounts or on the bolts themselves gave out....in essence we still have the same problem with what could cause the dropped motors......~sigh~
Now I understand tensil strength and the metallurgy behind why the bolt shouldn't break especially if installed correctly...(mine was installed with red locktight also).....however that doesn't inspire confidence when looking at the tripod the single mount screws down into on the tranny itself or the actual engine portion the two bolts for the damper screw down too.....they just look weak...(hince the failure of these and the bolts in the past)
I've seen PT performance has a transmission mount that in essence takes the vertical bolt and distributes the weight over it by turning it horizontal, the way Mazda "should" have done it, I'm seriously contemplating buying it..........Basically what I need to know is am I tripping or is this a legitimate cause for concern especially considering all the vibrations these three bolts are now being suscepted to overall......??? Appreciate any help/opinions.....thanks guys
Oh to my surprise my stock tranny mount was still torqued to specs when I removed it after who knows how many passes down the track
