traction control light
Have you tried resetting the ECU? Take off the negative and let it sit a few minutes and turn it back on.
Otherwise do what the manual says take it to the dealer. Honestly thats what I would do if resetting the ECU did not work.
if theres nothing wrong it may just go away. resetting itself after so many start/stop cycles. if not, you should take it in right away. if its still under warranty.
That happened to me once, i was stuck in my works parking lot and it took awhile to get out... i had snow up to my mirror.
