rockethead26
2019 CX-5 Reserve
- N. Arizona @ 7000'
Hi all,
Just changed to 18" wheels from my OEM 19" and added the Wildpeak 235/60 R18. The Falken is smaller, has a taller sidewall and is wider than OEM.
Running right now at 37 psi which is where I ran the OEM Toyo A36 which is 1 psi over recommended.
Here's the questions.
1) Does changing tire size/width necessitate modifying the tire pressure used? Is the recommended tire pressure for a car for the OEM tires or for any tire used on that vehicle?
2) Those of you running Wildpeak Trails, what pressure are you running?
Thanks,
Jim
Thanks,
Jim
