Wow... car hauls ass now with the timing adjustments... The JandS would show some mild activity once in a while, but i'd adjust timing in those spots and it would go away... So good in that department overall. Still some more timing that I can add in some spots to try and eek out more power as the JandS would never indicate.
But anyway.. roughly speaking... the car under 10 psi of boost from 3,000 rpm's to 6600 rpm's will creep from 26 degrees advance to 31 degrees of advance. The critical range where detonation would start to show was between 4500 and 5500. Most specifically a narrow range of about 4900 to 5200 was where I'd see the most intensity. So I'm running about 3-4 degrees less in that range than elsewhere and that took care of the issue.
I can't hear any detonation on my listening device (amplified knock sensor) and the JandS is cranked for sensitivity (about 90% of the way up I believe) and it has been content.
