Some thoughts on the new M5 after 1700 mile trip, Minneapolis to Englewood Fl, One 6 hour day, one 13 hours, and one 7 hour day.
First the seats which felt so form fitting and firm, took a bit of adjusting and still need something to make them really good, my wife in the passenger seat was really uncomfortable half way though the first day. Second the area from where the windshield meets the hood back to the outside of the driver side mirror is a bit of a blind spot for me even with the little window, especially at night, it might be where I am sitting and should get better as I get used to it. Third the brake peddle has too much play, when coming off cruise control, the cruise cuts out immediately but the peddle feels like it has too far to travel to get to serious braking. I am going to talk to the dealer about that. Also when I floor the gas sometime the transmission takes a bit of time to find the go gear, sometimes has to search for the right gear, a bit disconcerting when trying to hit a closing window of opportunity. The cruise control works great, the speedo is a little off relative to the gps, at 70 gps 71, at 75 gps 77, you might want to check yours.
Sounds like I had a lot of problems with the car, not so , we really like the car. It drives like it is on rails, you have to pay attention all the time (a good thing) we felt safe and made adjustments to the above which I am sure will get better with time.
Now for the really good stuff. We got all our go to Florida for the winter stuff into the car without blocking the rear window. The car had about 900 miles when we left. The trip was 1688 (odometer) and we used 57.5 gallons for 29.3 mpg. I am really happy with that. Mileage was taken off the trip meter, each tank filled until the first click turned off the pump. Speeds were 72 for first part of trip, 77 for second half, air was on for only the last 4 hours.
One note about the Scangage e, going up hill under hard acceleration pushed the gauge to read 9999 mpg, like we were coasting, shortly after it read abnormally high mpg on a flat road, it did readjust after a while.
A happy M5 owner
chuck
A happy M5 owner
chuck
